Shellac (as a sealer) drying time http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=55834 |
Author: | Juan CAR [ Tue Aug 15, 2023 3:09 am ] |
Post subject: | Shellac (as a sealer) drying time |
I have applied shellac as a sealer on an archtop guitar. I'm going to wait a week for drying to apply lacquer. Here we have temperatures of about 32º C and a relative humidity of around 40% now. Do you think that drying time is enough? |
Author: | bluescreek [ Tue Aug 15, 2023 5:18 am ] |
Post subject: | Re: Shellac (as a sealer) drying time |
You can do as little as 30 min if you use the flake shellac if you used can shellac your good to go in an hour a week is too redundant. Alcohol is the solvent and dries off fast |
Author: | SteveSmith [ Tue Aug 15, 2023 5:18 am ] |
I wait overnight. Steve |
Author: | Juan CAR [ Tue Aug 15, 2023 5:47 am ] |
Thank you for your replies! I never aplied before lacquer over shellac, hence my doubt because lacquer has a completely different composition. |
Author: | Clay S. [ Tue Aug 15, 2023 6:55 am ] |
Most lacquers contain some form of alcohol in addition to the other solvents used, so may dissolve some of the shellac. If shellac is used as a sealer or barrier coat it should be applied thinly and allowed to dry. If lacquer is applied over an existing (heavy) shellac finish it can dissolve the shellac and cause the finish to craze as the lacquer and shellac "dry" at different rates. Shellac when it gets old will not dry, so if your shellac isn't dry to the touch within an hour when applied thinly, it is probably too old and should not be used. A thin coat of shellac is often used as a barrier coat to seal oily woods to allow other finishes to be applied over top. |
Author: | rbuddy [ Tue Aug 15, 2023 7:47 am ] |
What Clay said, and you are using dewaxed shellac right? I usually test my shellac before applying it to an instrument by putting a spot of some on a piece of glass and if it is hard to the fingernail in 24 hrs I use it. If not, I use it on other projects like a door or something. I can't remember if that test was for shellac or hide glue but I use it for both. Anyone else heard of doing that? |
Author: | bobgramann [ Tue Aug 15, 2023 8:40 am ] |
A one pound cut of shellac seems to dry almost instantly after it is padded on. It can be followed in a few minutes by another coat. A two pound cut seems to stay soft for hours. |
Author: | doncaparker [ Tue Aug 15, 2023 9:57 am ] |
What Bob said, times two. |
Author: | bcombs510 [ Tue Aug 15, 2023 10:24 am ] |
And then add the acetone to the mix so you can literally watch it dry instantly. ![]() Sent from my iPhone using Tapatalk Pro |
Author: | bluescreek [ Tue Aug 15, 2023 11:17 am ] |
First off not all alcohol is the same . I never use canned shellac and I will not use denatured as there are chemicals in it we don't need. I only use EverClear and I make a 2 lb cut. This will dry in a short amount of time So Seal Fill Seal finish coats. I also grind my flakes in a coffee mill so they are dust for a better desolve and mix. You only need a coat after all we are sealing. |
Author: | Ed Haney [ Wed Aug 16, 2023 8:46 am ] |
bluescreek wrote: First off not all alcohol is the same . I never use canned shellac and I will not use denatured as there are chemicals in it we don't need. I only use EverClear and I make a 2 lb cut. This will dry in a short amount of time So Seal Fill Seal finish coats. I also grind my flakes in a coffee mill so they are dust for a better desolve and mix. You only need a coat after all we are sealing. John, How are you applying the seal coats of shellac? Spray, brush, pad? |
Author: | bluescreek [ Wed Aug 16, 2023 10:51 am ] |
I use a paper towel folded and use that as a brush you can use any method , I just find the paper towel cleaner and easy |
Author: | Juan CAR [ Wed Aug 16, 2023 1:42 pm ] |
Clay S. wrote: Most lacquers contain some form of alcohol in addition to the other solvents used, so may dissolve some of the shellac. If shellac is used as a sealer or barrier coat it should be applied thinly and allowed to dry. If lacquer is applied over an existing (heavy) shellac finish it can dissolve the shellac and cause the finish to craze as the lacquer and shellac "dry" at different rates. Shellac when it gets old will not dry, so if your shellac isn't dry to the touch within an hour when applied thinly, it is probably too old and should not be used. A thin coat of shellac is often used as a barrier coat to seal oily woods to allow other finishes to be applied over top. Thank you very much. I’m using new shellac from the can. |
Author: | Juan CAR [ Wed Aug 16, 2023 1:45 pm ] |
bluescreek wrote: First off not all alcohol is the same . I never use canned shellac and I will not use denatured as there are chemicals in it we don't need. I only use EverClear and I make a 2 lb cut. This will dry in a short amount of time So Seal Fill Seal finish coats. I also grind my flakes in a coffee mill so they are dust for a better desolve and mix. You only need a coat after all we are sealing. Thank you very much for your informative reply!!! |
Author: | rbuddy [ Wed Aug 16, 2023 2:23 pm ] |
Make sure your shellac from a can is DEWAXED shellac! |
Author: | Juan CAR [ Thu Aug 31, 2023 7:24 am ] |
rbuddy wrote: Make sure your shellac from a can is DEWAXED shellac! Thank you. The guitar is already finished and the result is very good. Lacquer on dewaxed shellac. |
